Old 11-11-2021, 11:11 PM   #1
Bruce Fulper
Liked 54 Times in 33 Posts
Default Re: Electric Fuel Pumps...
If you are running a QJet or any other non Holley OEM carb the bypass style is the way to go.
Montieth always ran his Hatari Qjet dead head. It was set up that way when I got the car so I tried and it worked flawlessly. Didn't see a reason to change. Ran at 6, 7 lbs.
Bruce Fulper is offline   Reply With Quote
Old 11-13-2021, 11:41 AM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Bruce ,I'm certainly not saying it hasn't been done that way successfully for years , most cars had a dead head system.
Technology and product advancements provided us with the options now available and having the return line is one of them ,especially with the newer high volume /pressure pumps that have flooded the market.
Old 11-13-2021, 08:42 PM   #3
Keith 944
Keith 944's Avatar
Liked 1,884 Times in 578 Posts
Just the regular is considered dead head as the pump is not just slammed shut but returning fuel there instead of another line from up front.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 11-14-2021, 09:24 PM   #4
Mike Rietow
Mike Rietow's Avatar
Liked 30 Times in 16 Posts
Any issues using a Holley return reg with a Aeromotive 1000? I just did a pump gas Wiseco 10:1 hydraulic roller engine for a 71 split bumper I rescued, plan to hot rod it on the street. I've already run a return +Holley Blue, Is Aeromotive durable for continual use, or is a Holley blue still the standard, anyone know? I'd like to put a quiet pump on this car. Just doing research. I've got aconstant duty relay on the blue, it screams.
7x S/Pro 'Sunshine" http://ottm.store
https://youtu.be/I8QWEaqeFRw
Mike Rietow is offline   Reply With Quote
Old 11-16-2021, 02:13 AM   #5
Adger Smith
Liked 880 Times in 311 Posts
The Holley blue regulator has a very small area. If you figure the area of the jets in your carb you need a similar or larger area in the regulator to get adequate flow. Otherwise the bowls start emptying as you go down track.
The lower float level could alter the A/F ratio.
The area also applies to Needle and seats.
2ea. .130 dia. N/S will out flow a single blue Holley regulator..
In the past when I ran Holley Blue regulators they were modified for increased flow.
If your a non believer take a blue Holley regulator apart and do some measuring.
The bypass regulator helps reduce air bubbles in the fuel and gives the carb a solid slug of fuel to get in the bowl. Most carbs don't care for air in the fuel & show it in performance.
How much HP are you making?.. HP requires LBS per Hr of fuel. Design a system that provides the correct LBS. Per Hour of fuel.
Adger Smith (Former SS)
Old 11-17-2021, 01:02 AM   #6
Mike Rietow
The car has a Holley return regulator. I'm wondering if this is the hot ticket with an A1000 Aeromotive fuel pump. Also wondering if an Aeromotive pump is designed for continuous duty. This is a street/strip car we plan on driving to the track in Orlando, a couple hundred miles round trip. It has a Holley Blue now, which is loud.
Old 11-17-2021, 09:11 AM   #7
Ralph A Powell
Liked 225 Times in 136 Posts
As I remember the diameter of the fuel passage in the old blue Holley regulator is only .224. When I was doing some development work on the first annular 4500 hundreds the Holley engineers told us that the cross over for a second regulator was 580hp. The old blues were very smooth operating regulator’s.
