Old 10-25-2021, 09:36 PM   #1
GTS340
Liked 1,345 Times in 410 Posts
Default Re: Raising Mineshaft Requirements To .95 Under For Stock
I'm not sure what the "welfare" game is. Some know where the best spot is for them on the qualifying sheet and run it to the 1000' mark. Personally I'm not good enough to know the best spot. Guys like Jody Lang do out west here. My car is fast in stock but I like Superstock where it's slow.. I'm not a "stock to the lanes" at 7:30 person I guess.
Paul
Old 10-26-2021, 08:09 AM   #2
Liked 10,757 Times in 2,236 Posts
Points for qualifying; like maybe 10pts for #1 spot, 9pts for #2, and so forth. Would national qualifying points be more than Divisional? Would it be the top 10% get qualifying points. 100 racers top ten get points, 128 racers top 13 get points, the AHFS always rounds up on any fraction of a whole number.
Old 10-26-2021, 08:40 AM   #3
Mike Pearson
Mike Pearson's Avatar
Liked 1,939 Times in 583 Posts
Maybe it would be better to consider a race mineshaft by the weather conditions. That is what it was actually intended for. Low temp, high barometer, low humidity and tail wind. So lets say below 62 degrees. Baro above 30.15 Humidity below 30% and tail wind above 7 mph. In my mind that is mineshaft.
Mike Pearson 2485 SS
Old 10-26-2021, 10:01 AM   #4
J.R. Haddad
Liked 1,470 Times in 308 Posts
Mike, I don't want to come across as argumentative, maybe just comparing
regions. At lots of races that I have attended over the years in the Midwest,
I would consider a barometer of 29.5, temp of 75 or less, humidity of 50%
or less, and no wind as mineshaft capable. I can only dream of the conditions you describe at a National Open. I don't know the answer,
but I'm not sure there is a problem. NHRA makes it tougher, racer's get
more creative, what was "GRAY" area, gets missed for a while, NHRA
figures it out, but then realize 40% of the racers are doing it, so it becomes
O.K., and everybody does it=more cost. I think that is where we lose a
lot of racers. Want racers to run it to the finish line, Reward Them.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 10-26-2021, 10:36 AM   #5
James Perrone
Liked 1,829 Times in 427 Posts
It only effects Division 1
We hit the mineshaft more than any other division
We are Bad azz fast over here. D-1. Or we live in fantasy land
Not for the weak.
james perrone 1290 STK
Old 10-26-2021, 11:31 AM   #6
Billy Nees
Liked 7,780 Times in 1,743 Posts
J.R.
>>>>>>>>>>>>>>>>>>>>>>>>>Bingo!<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
Billy Nees 1188 STK, SS
Old 10-26-2021, 01:57 PM   #7
Mike Pearson
J.R.
You are no argumentative at all. Just threw that out there to see what some thought. Those numbers are some that we see here early and late in the season at D-2 events periodically. We can and do get those numbers at the early points races here in Florida like the orlando race or the baby gators.
Old 10-26-2021, 03:14 PM   #8
I wouldn't have a problem with -.85.
Good idea...I'm surprised NHRA adopted it.
I suppose having AHFS at Indy is okay too. It's going to be mineshaft anyway.
Having 2-3 cars that run 1.5- 2.0 under there just showcases what a p. poor job they did at factoring them in the first place.
Old 10-26-2021, 10:37 AM   #9
JeremyDuncan
Liked 355 Times in 80 Posts
So when would these weather conditions apply?
8am? 12pm?
Beginning of Stock qualifying?
Beginning of SS qualifying?
Each pair of cars?
What if the parameters were met at the beginning of a session then you had a 2 hour rain delay in the middle of qualifying would they still apply?
Using weather Data is just too unwieldy!
JeremyDuncan is online now   Reply With Quote
Old 10-26-2021, 11:35 AM   #10
DG
DG's Avatar
Liked 449 Times in 98 Posts
Instead of penalizing performance, NHRA should incentivize performance.
Cash, plaque and 10 points for #1 qualifier, 5 points for #2 qualifier
10 points for setting record
Qualified field at National Events
Cash and 10 points for winning class
Incentives will be more fun and get quicker results than just establishing a new line in the sand.
DG is offline   Reply With Quote
