Old 10-19-2021, 04:35 PM   #1
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: 8.50 index build
Originally Posted by Greg West View Post
Beautiful workmanship. Just curious what brand of welder you use at home?
Thank you.
I have an Everlast PowerTig 255ext water cooled. I took it to the shop when doing the tube work so everything on the car was done with this welder.
Todd Geisler is offline   Reply With Quote
Old 10-20-2021, 12:52 PM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
T.I.G.H.T I would not like to be your starter.
Dale Shearon
68 Mustang 6394
Old 10-20-2021, 01:40 PM   #3
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Did you make those collectors ?
Old 10-20-2021, 03:55 PM   #4
Todd Geisler
No, the collectors and mufflers are from Stainless Headers. I just had to weld the muffler to the collector and add the turn-up at the exit.
The flanges and primary tubes are from SPD.
Old 10-20-2021, 03:53 PM   #5
Todd Geisler
Not sure what you mean about the starter.
If you mean header tubes and the starter, the closest tube is at least 2 or 3 inches away. can take the starter on and off and connect/disconnect wires without removing any header tubes.
Old 10-21-2021, 03:26 PM   #6
FireSale
FireSale's Avatar
It looked tighter in the photo I was looking at. The sweep of the pipes gives a lot of clearance.
Dale Shearon
68 Mustang 6394
Old 10-22-2021, 04:57 PM   #7
Troy Henderson
Troy Henderson's Avatar
Liked 129 Times in 41 Posts
Thumbs up Re: 8.50 index build
Beautiful work, thanks for posting!
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 10-22-2021, 09:35 PM   #8
monte385
Liked 27 Times in 19 Posts
Nice work Todd, I always followed your Malibu build on Team Chevelle. Sure a shame about that car, but glad you came out of it OK.
monte385 is offline   Reply With Quote
Old 10-23-2021, 08:19 AM   #9
Todd Geisler
Thank you. Feel lucky to be alive after that accident.
Old 10-23-2021, 08:17 AM   #10
Todd Geisler
Thanks Troy!
