Old 10-14-2021, 06:19 PM   #1
Liked 16,560 Times in 1,523 Posts
Default "Live From" Bristol - Thunder Valley Nationals
Hey guys, I just pulled in... I have not been to this track for over 10 years, man how things have changed. Anyway, as most of you know the schedule has changed. Sportsman will get 2 rounds of eliminations instead of 1. Stock will be out first at 8:30am and then its the typical rotation until eliminations... things will be moving fast tomorrow.
I will do my best to get photos, I do have media credentials, but I may not have time as the sportsman are on a tight schedule. If I get a good run in our first qualifier, I'll skip the second, that should give me plenty of time to get some starting line shots.
The weather tomorrow looks good, but Saturday looks a lot cooler and rain in the morning.
I did find a few cars out...
ID:	60761   Click image for larger version
ID:	60762   Click image for larger version
Old 10-14-2021, 10:30 PM   #2
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
Default Re: "Live From" Bristol - Thunder Valley Nationals
Whos wagon ?
Jake Biermann
Old 10-14-2021, 10:57 PM   #3
kwm
kwm's Avatar
Liked 4 Times in 3 Posts
Whos wagon ?
I believe that is Kyle Anderson I/SA 350 Malibu wagon
Kenny Miracle
P/SA 310
kwm is offline   Reply With Quote
Old 10-15-2021, 08:26 AM   #4
Ralph A Powell
Liked 225 Times in 136 Posts
8:25 am
temperature = 61.91 deg f
relative humidity = 97 %
uncorrected barometer* = 28.43 inHg
corrected barometer* = 30.00 inHg
wind speed = 2.15 mph
wind direction* = SE (162°)
more info: current metric | historical | forecast | help
dew point = 61 deg f
saturation pressure = 0.558 inHg
vapor pressure = 0.542 inHg
grains = 84.5
air density (w/o water vapor) = 95%
air density (w water vapor) = 93%
density altitude = 2513.07 ft
Old 10-15-2021, 08:59 AM   #5
Frank Castros
Liked 2,727 Times in 961 Posts
Is there no live timing from Bristol this morning?
Old 10-15-2021, 09:07 AM   #6
Liked 10,721 Times in 2,232 Posts
No live timing, what a gyp!!!!!!!!!!!!!!!
Old 10-15-2021, 09:13 AM   #7
Good morning all, no live timing... not sure what the issue is. There is no one here that I can talk. I went to get my media vest and there is still no one around. We just made our first shot down the track, and it was pretty foggy but the track seemed ok. Its slow here as always, bar is 28.45.
I have to make another run so photos will be a little light this race. I will do my best to get some shots. If anything I will get shots from the pits or the stands.
Be back later...
Old 10-15-2021, 09:34 AM   #8
Frank Castros
It just came up.
Old 10-15-2021, 11:37 AM   #9
Hey guys I'm back, we are moving quick, Super Stock is in the lanes for their 2nd qualifier. First round for Stock should be up in the next hour or so. I did manage to get some phots of Super Stock. Here is one set, I will have more later. If I go out early I will get photos for Stock.
ID:	60768   Click image for larger version
ID:	60769   Click image for larger version
ID:	60771   Click image for larger version
ID:	60772   Click image for larger version
ID:	60774   Click image for larger version
ID:	60775   Click image for larger version
Old 10-15-2021, 12:16 PM   #10
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
A problem with schedules like this is if you break something you are out of luck! there really is no time between runs or eliminations to get anything done. it’s so sad, even if you did break something you’re not going to go into the manufacturer’s midway and get the parts you need. Boy, how things have changed!!!
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
