Old 10-08-2021, 08:09 PM   #1
brian schuetta
Liked 28 Times in 15 Posts
Default Re: 2-barrel Roch Only Questions
Didn't the 305 in a 76'-77' Camaro run the 1.375 2-barrel?
brian schuetta is offline   Reply With Quote
Old 10-08-2021, 09:29 PM   #2
NO.
Well probably lots of year cars run them but only legal on two years of 350s ;-)
Old 10-08-2021, 10:17 PM   #3
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: 2-barrel Roch Only Questions
How about the 2 barrel 265 horse 396?
Old 10-08-2021, 10:48 PM   #4
1.25...Same as the 327/ 235.
Also same as the 71 and newer 350
Old 10-09-2021, 11:18 AM   #5
MikeMoller
MikeMoller's Avatar
Liked 254 Times in 78 Posts
I tested the difference/gain between the 1.186" 1.250" on my 305 Nova, and on the 75 350 Nova combo. Was only worth a tenth on both combo's.
Mike Moller
NHRA 203 Q-R-T/SA
Old 10-09-2021, 12:08 PM   #6
oldskool
oldskool's Avatar
Liked 747 Times in 362 Posts
Now there's some useful info !
Thanks for posting it !
Now, for some of you serious 2-barrel Roch racers. Who are some of the best 2-barrel roch carb builders who are CURRENTLY building them ?
Don't need the names of those who use to build 'em & are no longer doing it.
What is the aprox cost of a 1.186 & a 1.25 nowadays, including the core ?
Don't have to be for a class winning record holder. Just a good competitive carb to run just under the index of an average combo.
These may seem like REAL dummy questions. But, if I knew the answers, I wouldn't ask the questions.
(1) Is a good 2-barrel Roch any more consistent than a Q-jet ?
(2) Is it easy to get a 2-barrel Roch to launch(start the timers) consistently, so that you can dial in your RT, pretty close, on the tree.
You can compare it to a Q-jet, which is what I've always used. Have no idea how much different running a 2-barrel is.
Old 10-09-2021, 02:55 PM   #7
NORMAN BARNARD
Liked 2 Times in 2 Posts
I've been doing the 2-bll. Rochesters for the c/track guy's here in the southwest for several years. Lil known secret to make them run is not necessarily in the venturi housing but in the
booster cluster, float prep., and proper jetting.
Oh, and were at 4000 ft. Above sea level with a air density altitude
of 6500/7000 ft. On race day..
NORMAN BARNARD is offline   Reply With Quote
