Old 10-08-2021, 02:13 PM   #1
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Stick vs Auto
i have comparison that may help...
my car was F/pure stock.305/160-230 (IHRA rating)350 TH 2.75 low gear set,low volume pump..
changed over T-10 2.88.1.75,1.33.... best with auto was 8.28 1/8 third pass with stick went 8.02 eventually went 7.68/12.30 without any changes to engine..
later converted to K/S ran 11.85 with T-10 broke it a few months later switched to jerico and went 11.66 first pass....
was converter perfect.NO but i had done all I was going to do with it...adjusted all it could be..... when i switched over was clutch perfect NO...and never was,but best I could do... 7.68/12.30 on 8.90/13.75 index was best I could do...
Old 10-08-2021, 04:58 PM   #2
Dave Gantz
Liked 251 Times in 125 Posts
Some people may not be physically able to race a stick. I had a friend who could street drive a stick, but there was no way he could race one.
Old 10-08-2021, 07:23 PM   #3
Tom Meyer
Liked 354 Times in 120 Posts
Ls auto to a stick goes from 382 hp to 357 or 25 hp less. 8.5 class x 25 hp less is 213 lbs. Maybe 2 tenths fast with a stick. If you look a well known stock racer just put stick in his mustang Tom.
Tom Meyer 5240 SS Stock ???
Old 10-08-2021, 08:56 PM   #4
Jim Grande
Liked 18 Times in 9 Posts
I have run my SS/D 69 Camaro both ways and it is a solid .20 quicker with the stick!
Auto is ATI TH400 with ATI converter. Stick is GF5R Gforce with Mcleod softlock clutch.
Perhaps a ProTrans would narrow the gap but the stick would be quicker and waaay more fun!
Jim Grande is offline   Reply With Quote
Old 10-09-2021, 03:29 PM   #5
weedburner
Liked 20 Times in 16 Posts
Stick has the potential advantage of launching at a much higher rpm than an automatic.
Here's one of my ClutchTamer customer's sealed engine Coyote Stock graphs from several years ago, it clearly shows stored inertia energy contributing quite a bit to the car's initial acceleration rate. Energy that was stored prior to the start of the clock, then un-leashed after the start of the clock to boost acceleration. Notice that all the highest points of the Accel "G" trace on the graph occur while the engine's rotating assy is losing rpm (discharging energy) against WOT. But then as soon as the clutch stops pulling the engine down and engine rpm begins to climb, the G trace drops like a rock as engine torque alone is now accelerating the car with no help from discharged inertia...
Just something you might not notice if you are currently "driving into the clutch" like a lot of class racers do.
Grant
Grant
website- http://ClutchTamer.com
We make your non-adjustable clutch...ADJUSTABLE!
weedburner is offline   Reply With Quote
Old 10-09-2021, 11:13 PM   #6
Jim Hawkins
Liked 115 Times in 35 Posts
My SS/I 327 camaro lost .35 going from a jerico to a powerglide. This is up here in Denver. It needs a 3 speed but the stick will still be much faster.
Years ago with a bracket motor in the car went 11.20 with a glide. First time ever with a stick in the car went 10.66 first time out.
Jim Hawkins is offline   Reply With Quote
