Old 10-07-2021, 04:00 PM   #1
Liked 5,120 Times in 1,951 Posts
Default Re: 2-barrel Roch Only Questions
1.18 carb is the same size as the 305s ..Some of them are under 180 hp. In U/SA , a Pontiac would have to weigh 600+ pounds more, in the same class.. No thanks..
I didn't even mention the 302 FFFFFFords.
The big inch Pontiacs had a 1,250 carb, I believe. Same as the smog 350 Chevys.
The 69-70 350 Chevys have the big 1.375 carb. That's the one that the restricted circle burners use.
69 Chev 350 2v is good. The 70 is even better... 70 4 dr. Nova should run low 12's in N/SA, with no roll bar , belts ,and monkey suit requirements..
One of the best 2V deals is of the blue oval persuasion, but is stick shift only, and we now know it's harder to win with that extra pedal. ;-)
