Liked 237 Times in 126 Posts
If the Windows Update killed your ability to use the Altronics software you don't have many pretty options. Microsoft won't let you "downgrade" back to where it worked. You could find a used laptop running a version of Windows that works and turn off Auto Updates. Then use this as your track computer. The other is to fork over the $100 for the Altronics update. Either way, when you get things working get a backup drive and make a full copy of your laptop every week. That way if it freaks like this again, you have a working duplicate on a spare hard drive that can be changed out for the one in your laptop with a screwdriver.
Liked 1,580 Times in 582 Posts
If you need to update your Windows software, go to this link and you can purchase your operating system and other updates for a lower price.
https://pcsalesonline.com/software/o...ms/windows-10/ |
Liked 57 Times in 24 Posts
I have windows 10 on the laptop. As far as I know you can
not stop the auto updates. You can delay the update check but not stop them.I guess If the pc is never connected to the web would be a way . The RaceWork software is non transferable The license must be generated from a file sent to Altronics. I think it generated from the cpu or hard drive ser # My question to Altronics is why it went to expire mode. If it Is a windows update that caused the problem , there should be other user with the same issue. David |
#4 | |
https://support.microsoft.com/en-us/...0-54eea0f45938 https://www.laptopmag.com/articles/s...ode-windows-10 |
#6 | |
Now if I can get the software to run again |
Liked 1,919 Times in 576 Posts
Have you talked to Fred at Altronics about this. I have their software as well and he will send you an update if you are current with your membership. When ever I have issues his updates have fixed it. He is usually very helpful. Give him a call or send an e mail to them. He will respond quickly.
Mike Pearson 2485 SS |
