Old 09-07-2021, 03:11 PM   #7
e vassar
Liked 273 Times in 109 Posts
Default Re: Titan Towing question
Originally Posted by 340Cuda View Post
What is the rated towing capacity of the truck?
Can you tighten the the bars more on the equalizing hitch to get more weight on the front of the truck? If not I would consider air bags.
Does the truck have LT tires? I have heard of trucks that come from the factory with passenger car tires, for a better ride, that can have towing problems. If you have a mix of both that might not be good.
Good Luck!
9500 lbs ...sounds a bit optimistic to me.
I might need to work on my hitch set up because it really doesn't help much with the rear squat.
