Old 09-05-2021, 05:56 PM   #1
Tom Goldman
Tom Goldman's Avatar
Liked 886 Times in 238 Posts
Default Re: Question for Powerglide Wizards
Originally Posted by reknapp52 View Post
On the subject of Powerglides--I have been using a stock-case glide in my car. Anyone have comments about the aftermarket cases that are available, problems that might have been encountered? Thanks--
More problems with stock cases , especially when running a valve body with line pressure over 200 psi. .....Sooner or later it will push the side of the case out at the adjuster bolt.
If you're buying a new case ,I have seen issues with many of them , although mostly minor . mostly bolt holes not tapped all the way through , pump bores not properly champhered . ....... Reid / Dedenbear is the exception, never had any problems with them.
