Liked 20 Times in 15 Posts
the ? remains, except for you guys with mega $$ and a go pro camera mounted under the car to view movement...how do you know what the pinion is really doing. every car is different even if it is the same car [1 67 Camaro next to a duplicate 67 Camaro]
just because 1 guy says 4 degrees down tells you absolutely nothing. so the pinion is 4 degrees down, down from what, the ground? the difference is between the pinion and the driveshaft. if the pinion is 4 down and the shaft is 4 down, then you have 8 degrees. [and y7ou could still have 0 to 1 degrees at the tailshaft] loss of hp, and a broken U-Joint in your future. spring packs are different in stiffness. spring pads are different [most only a bit longer than housing dia. and therefore, offer very little resistance to movement]. shock position [front or rear of axle] shock stiffness [front or rear], tire size and width, tire pressure, launch RPM and launch hp,track traction and probably several more things cause pinion angle to change at launch. and how long will it stay. all in all, be careful about making general statement about someone elses pinion angle. Rod in AZ |
#2 | |
Liked 30 Times in 16 Posts
This is where you're getting confused, Cal-Trac doesn't specify pinion angle, only they want the pinion down. This is to get the shaft of the damper exiting the shock/dampers main body with the shocks fixed on the backside of the rearend housing, at the drop. Last edited by Mike Rietow; 08-29-2021 at 08:34 PM. |
Liked 253 Times in 95 Posts
The angle you need to be 2-4 deg. Is the one between the driveshaft and pinion. The pinion should be pointed slightly down compared to the driveshaft. This needs to be checked with the suspension at ride height.
George Mirza D/SA 1236 ‘71 Duster 340 |
The only way to find the perfect pinion angle would be to keep changing it and making runs until the car goes the fastest. 2-4 deg. Is a good starting point and is usually in the ballpark.
George Mirza D/SA 1236 ‘71 Duster 340 Last edited by Gmirza; 08-29-2021 at 09:14 PM. |
FireSale, the caltracs don’t stop the axle from rotating. The rotation of the axle creates the body separation. The bars stop the spring from wrapping up and transfers the weight to the tires. The twisting of the axle housing is the energy that makes the suspension work. It takes traction to make traction.
George Mirza D/SA 1236 ‘71 Duster 340 Last edited by Gmirza; 08-29-2021 at 09:30 PM. |
