Old 08-13-2021, 12:10 PM   #1
6130
Liked 117 Times in 50 Posts
Default Re: Time For A Transmission Rule Change?
An existing transmission rule that appears to not be being enforced, is the rule stating that you have to use the clutch to change gears, and specifically banning clutchless gearboxes. I'm not gonna point fingers, but I'm seeing a lot of in-car videos of stockers clearly showing gearchanges made without touching the clutch.
Old 08-13-2021, 02:27 PM   #2
joe collins
Liked 22 Times in 16 Posts
you pull it hard enough don't need to use the clutch
joe collins is offline   Reply With Quote
Old 08-13-2021, 02:30 PM   #3
Chris1529
Liked 70 Times in 29 Posts
I have a 2004 Dodge 2500 diesel and an 83 Mustang GT with a T-5 that I can shift without the clutch, neither at WOT, but I'm pretty sure just about any aftermarket stick shift can be shifted w/o clutch.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 08-13-2021, 03:59 PM   #4
6130
The rule defines how the transmission is to be used, regardless of what it is capable of.
