Liked 209 Times in 90 Posts
Dirtmod I am not familiar with the SSGT stuff to advise you very well. It looks like the 383 can not be used in SS or SSGT in a 1973 Barracuda. When you go here,
http://nhraracer.com/content/general...635&zoneid=132 None of the GT listing show the 383. Mopar and SSGT guys please chime in. Ray
Ray Bassett I/SA 1687, SS/DA 1687 "SuperPro is both", unknown |
Liked 883 Times in 237 Posts
One thing that's been overlooked in the conversation is since you have only a 8 point roll bar ,you are limited to to a combination that falls into SSGT/E or F ,and then only if you run the index . Even dropping to a lower class will need a cage if you run under the index.
Most viable combinations that can fit the car most likely will need a roll cage . Before jumping into the "shark pool" ,visit a Lucas Oil Divisional race and seek out some racers that are running Mopars in SS . Most will at least tell you what may not be a good combo and more than a few will at least steer you in the right direction.
Liked 1,345 Times in 410 Posts
The best bang for the buck is a 73-340 rated I believe at 242 hp. or a 74-360 rated at 265 in Superstock. You can claim either or without any trim change. Once you get into classes that have potential of running 9's you need a lot more safety equipment. ( cage, certified cage, transmission and flywheel shields. window net, grade 4 license which add to the yearly expense in some cases). I'm not a fan of a 8 3/4 if you trans brake. Specially a big block. You can run a worn out stocker small block in Superstock these days at this hp rating.
Best of luck, Paul Haszlauer C/SA 7019 |
Saying You can run a worn out stocker small block in Superstock these days at this hp rating. That means you already have light weight everything, 4-6 grand invested in the torque converter and transmission, custom headers and other stuff.
Paul |
