Old 07-13-2021, 05:59 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Re: "Family Tradition" a build for Daughter & Grandchildren
When converting a factory stock truck to a drag race truck, it is necessary to turn all bolts anti-clockwise. Later, after modifying each piece, bolts can be turned clockwise.
ID:	57659   Click image for larger version
ID:	57660   Click image for larger version
Larry Woodfin 471W
Old 07-13-2021, 06:01 PM   #2
Dragsinger
Jake, it is a footbrake [bottom bulb] bracket racer.
Larry Woodfin 471W
Old 07-23-2021, 09:05 PM   #3
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
'Singer... Are the rear tires like a 29.5 x 11.5 or 14 x 32? MB
MAURICE BLENDHEIM is offline   Reply With Quote
Old 07-23-2021, 09:20 PM   #4
Dragsinger
Maurice, 29.5 x 11. The wheels and tires pictured are for mockup, and I will likely run a radial in the 29.5 x 11 range. The bias tires pictured are new but several years old. I might run the bias for a few test outings.
Larry Woodfin 471W
Old 08-02-2021, 04:43 PM   #5
Dragsinger
A few updated photos.
ID:	58112   Click image for larger version
ID:	58113   Click image for larger version
Larry Woodfin 471W
Old 08-02-2021, 05:05 PM   #6
Dragsinger
When the frame mods are complete, all will be braced and triangulated as needed. Another cross-member will accommodate the shocks, and the Antiroll bar will be in front of the diff.
Larry Woodfin 471W
