Liked 973 Times in 310 Posts
Did you check the transmission mount and driveshaft while your at it.
Liked 71 Times in 38 Posts
Just a thought, but did you try unbolting the torque converter and running the engine?
Liked 43 Times in 29 Posts
I recall a GM service bulletin that addressed engine vibrations, It had to do with adding a shim type spacer between the block and mount. I believe the issue had to do with alignment of the motor mounts. I don't recall what years it was related to. On another note make sure that the motor mount bolts going into the block are not bottoming out before the mount is completely tightened,
Mark Ruset 2048 STK |
