Old 04-30-2021, 09:02 AM   #1
jmcarter
jmcarter's Avatar
Liked 3,169 Times in 970 Posts
Default TPMS Recommendations
This topic has bled over to a couple of unrelated threads so here goes. Recently upgraded to enclosed aluminum trailer and DO NOT want to see all that aluminum messed up by a tire failure or change a tire on a narrow shoulder off I-75 (been there, done that). It would seem these are the leading candidates but inviting endorsements and recommendations including insight on the flow-thru sensors and need for a booster.
https://eezrvproducts.com/
https://tsttruck.com/
Thanks in advance...
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-03-2021, 09:31 AM   #2
Bill MacDonald
Liked 2 Times in 1 Post
Default Re: TPMS Recommendations
Jim: I just ordered a TST one on Friday & I wanted to set it up to see how it worked. I check with some of the full time rv's to see what they thought & they liked it because of the screen & size. I've got a tri axle trailer & I used the out side tires on the screen but I would read ALL instruction first so you will understand. If you go this route the TST Truck web suite go to the bottom & click on faq's & look at all the videos. I got this model, TST-507-RC-6. Which is the colour screen with 6 pressure caps. Not the flow through . The unit comes with battery's in the caps & all charged up . I got my from Amazon but there's a dealer down your way called. Techno RV which is same price but they are there if you have any problems setting it up. I hope this helps. Bill
Bill MacDonald is offline   Reply With Quote
Old 05-03-2021, 10:16 AM   #3
340Cuda
Liked 799 Times in 336 Posts
This system has been mentioned also:
Pressure Pro https://pressurepro.us/
Old 05-03-2021, 10:46 AM   #4
Keith 944
Keith 944's Avatar
Liked 1,876 Times in 577 Posts
I decided on the https://innovationtire.com/product/t...-and-trailers/. 10 sensors. With a coupon code of endlessrving20 saves $20. So under $400.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Keith 944 is online now   Reply With Quote
Old 05-04-2021, 11:38 PM   #5
voltdr
Liked 100 Times in 51 Posts
I've had the EEZRV system on my trailers for over 5 years. It just saved me from a blowout coming back from GA on Saturday morning. I picked up a small oblect that caused a slow leak. The alarm went off at my preset low pressure warning. Got the tire fixed and continued on with the same tire. BTW, since having this system, it has saved me on three other occasions also. The peace-of-mind while traveling is very nice. Along with my AFG Fireballs, I travel much easier.
Hit me up if you would like more info about the Fireballs.
Dan
SC 4698
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 05-05-2021, 07:23 AM   #6
Keith 944
Keith 944's Avatar
What is an AFG Fireball??
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 05-05-2021, 07:49 AM   #7
jmcarter
jmcarter's Avatar
Think Dan is referring to the mini fire extinguishers...he can correct me if he’s pointing elsewhere.
Thanks for the TPMS suggestions. I’ll study the options, now on to selecting a GPS tracker to hide in the trailer. I HATE thieves!
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-05-2021, 08:55 AM   #8
Keith 944
Keith 944's Avatar
Sounds like another good thread
that also is on my list of goodies
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 05-05-2021, 11:32 PM   #9
voltdr
Dan Foley
SC 4698
Old 05-05-2021, 11:44 PM   #10
voltdr
Keith,
I’ve used this one for over 4 years. No subscription, just buy a SIM card.
https://www.ebay.com/itm/Coban-track...-/401450362456
Dan Foley
SC 4698
