Liked 10,678 Times in 2,221 Posts
It might be a good "Dairy Queen" cam. I never drove anything on the street with one of these cams but for $100.00 how can you go wrong. the best thing about a used cam is it's broke in.
I would recommend dialing the cam it with a degree wheel and checking valve clearance at split overlap to make sure the piston is out of the way. |
Liked 2,462 Times in 694 Posts
Are the Isky cams new?
If so I will buy them if the are set up for Hyd. Lifters
I will look today
Isky brand new in the box has never been out been unwrapped
109* 1651 on the box. TCS, just a guess, it might stand for Tri-City Special. Number on the box 041560-4 109. When we ground cranks I removed the fuel pump lobe. |
I will buy the Isky
PM me you contact # Thank
Isky cam and is sold thanks Class Racer.
