Old 03-31-2021, 02:21 PM   #1
ausby
ausby's Avatar
Liked 34 Times in 18 Posts
Default Re: The Future Of The .90 Classes
i hope it stays around a while. im new to the .90 stuff and like it alot better than bracket racing.
Ausby Brewington
A231 S/G
ausby is offline   Reply With Quote
Old 04-08-2021, 09:37 PM   #2
Joe Shiver T/S SST
Liked 2 Times in 1 Post
I went from Top Sportsman back to Super Street and love it hope it stays around and car counts are great I say leave well enough alone. I also think that super street gives the ability for some drivers to drag race who maybe can't pass the physical to go super fast but still want to compete and have fun. So no I wouldn't want to see an index change.
Joe Shiver T/S SST is offline   Reply With Quote
Old 04-09-2021, 03:29 PM   #3
Maverick
Liked 36 Times in 26 Posts
I think it would really mess up the class to lower the indexes. It ok if you have a mega inch motor in a roadster, and can 170. You want to change the index, then do it and I will retire for sure. The hi mph cars have the advantage most of the time, but there are a few racers that run the number at 100 mph. The problem with people wanting to change the index is they can't run without it. 9.90 hi mph car would run low 8's. They allowed the delay, throttle control boxes, which are just computers manipulating the throttle control, and release of the car. Too much politics in the class. Steve Williams. S/G 351N 1994 Ford with no throttle control, or hi moh
Old 04-09-2021, 03:32 PM   #4
Maverick
I think it would really mess up the class to lower the indexes. It ok if you have a mega inch motor in a roadster, and can 170. You want to change the index, then do it and I will retire for sure. The hi mph cars have the advantage most of the time, but there are a few racers that run the number at 100 mph. The problem with people wanting to change the index is they can't run without it. 9.90 hi mph car would run low 8's. They allowed the delay, throttle control boxes, which are just computers manipulating the throttle control, and release of the car. Too much politics in the class. Steve Williams. S/G 351N 1994 Ford with no throttle control, or hi mph. You want to lower the index, jump move up a class. You run super gas, run super comp, problem solved
Old 04-09-2021, 09:02 PM   #5
BKSG1198
BKSG1198's Avatar
You could also do what they did out on the West Coast a few years back and did a 7.90 class with a mix of dragster and roadsters. Keep the other classes the same with the indexes for those who don't have deep pockets and create a 7.90 class for those who want to go fast. I don't remember the results of the event but, I think it was held at Sonoma.
Old 04-09-2021, 10:44 PM   #6
Regan Wilson
Regan Wilson's Avatar
Liked 134 Times in 70 Posts
We all voted years ago on the subject of lowering the Indexes. The vote was not to change anything. I can't recall what year it was.
Regan Wilson is offline   Reply With Quote
Old 04-10-2021, 09:20 AM   #7
Jason Oldfield
Jason Oldfield's Avatar
Liked 10 Times in 4 Posts
Send a message via AIM to Jason Oldfield Send a message via MSN to Jason Oldfield Send a message via Yahoo to Jason Oldfield
That's sorta what I was going to suggest, though I might change that up slightly. Just thinking out loud here...
You can't really just move all the indexes up 1 second because as somebody mentioned you would force out a lot of the S/St racers (that jump in index requires a lot of additional safety equipment, including chassis certification (not that they shouldn't have it anyway, but that's another topic altogether).
In my opinion, NHRA hurt S/St when the made it so that you could race more than one category if you raced S/St. A lot of really good, experienced S/G guys moved down the instant they were able to do that.
So, I would move S/C up to 7.90, S/G up to 8.90, S/St up to 9.90, and make a new 10.90 class with a few rules modifications.
For the new 9.90 S/St I would reduce the minimum weight requirement to 2100 lbs., but otherwise leave the class exactly as is.
For the new 10.90 class, I would use the current S/St minimum weight of 2,800 lbs., and go back to 1 entry only. I'm thinking stock bodied vehicles only (no fiberglass replicas). Maybe no chassis cars (back half cars only). I would also seriously consider electronics restrictions. No programmable ignition boxes? No data recorders / electronic dashes? Manually shifted cars only?
Again, just thinking out loud here and trying to think about the typical low 11 second bracket racer that is thinking that they'd like to dip their toe in the water and give .90 racing a try. You're not going to do that if you immediately believe that you'd have to go spend $5,000 in miscellaneous electronics to make your car competitive.
I'm sure all of you could come up with some good suggestions. I want to see these classes survive, but I really don't believe they will if they continue running the way they are. For now, NHRA is OK with it because there are still plenty of competitors. But the average age competing in each class is continually rising, because it's just us same old competitors getting older. We need to have a real entry-level class that your typical young, enthusiastic drag racing competitor can get into without:
1. Breaking the bank
2. Feeling like they're bringing a knife to a gunfight
3. Being embarrassed about the state of their racing operation as compared to the typical competitor in the class
Regardless, thanks for the initial, thought provoking post, John. It's good to see some familiar "faces" again...
Jason Oldfield
S/G & S/St 1838
Jason Oldfield is offline   Reply With Quote
Old 04-10-2021, 07:08 PM   #8
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
I've always liked Super street but never got why it was never treated as a national championship class.
Jake Biermann
Old 04-11-2021, 09:41 AM   #9
Dano
Dano's Avatar
Liked 52 Times in 32 Posts
Just my opinion......leave the SST index and weight alone. limit to real cars with doors. As NHRA has spun the class as "entry level", the MPH should also be governed. Maybe a limit on MPH. It should also be included at all National events.
SC 707Y
Dano is offline   Reply With Quote
