#1 | |
Liked 269 Times in 99 Posts
When you change fuel pressure the whole map is leaned out or enriched. Chances are your idle is fat but the rest of the map is close. adjusting the cells used art that RPM and Load will take care of that easily. Raising fuel pressure makes the injector think it's larger there is a limitation on how high you can go based its construction. When an injector is tested and sized it is based on a specific pressure one thing to consider asking your supplier how high can fuel pressure be raised until the injector does not operate efficiently. Changing injectors to enrich or lean won't be accurate or recommended. The ECU has info on the specific injector characteristics changing them out without telling the ECU will make fueling inaccurate. Your concept: injector size is scalable may be true when using the same model line if available. The idea of replacing injectors in a performance application is to size it to the fuel demand choosing a model that atomizes well is fast acting reliable and fits the manifold. Your thinking is in the right direction but you must do some reading and ask questions methods you're considering are a real hatchet job! Don't know your case but if known good tune was flashed to your ECU that is just a starting point and could be the cause of your idle issue since that tune may work perfectly on the engine is was developed on. Have you run the car on a chassis dyno with a good tuner? If no the time and money will be well spent and you will learn a TON! When the tune is optimized on the dyno with a good tuner you will be well in the ball park with only minor tuning necessary at the track if you so desire. Load at the track is different from any dyno engine or chassis. Many are intimidated by EFI tuning but all it requires is an understanding of how it works some time building confidence a calculator pad and pen. The most valuable advise anyone can give a new tuner is to be sure to save every map changed with a unique name to assure when you get off into the weeds which we all do it's as simple as installing an older tune and back to where you started that rabbit hole. Goof Luck!
