Old 02-24-2021, 08:15 PM   #1
SSDiv6
Default Re: New Technical Inspection Addendum
Originally Posted by e vassar View Post
That would be tough on some of us since the one box not only records data, also operates injectors coil packs etc . It is legal to record data,but not legal to display driveshaft , wheel speed etc to driver during run.
You do not need to display the data during the run; the ECU can be programmed to use the inputs to perform specific actions.
Old 02-24-2021, 08:18 PM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
The fully detailed run data for national events and most divisionals has been public for a few years now.
Anybody see anything fishy in there?
S/ST 51
S/C 53
Old 02-24-2021, 08:38 PM   #3
e vassar
Liked 272 Times in 108 Posts
SHOW ME HOW!.....Sorry couldn't resist
But yes you are right. ..sensor data controls injector duration, timing,etc to repeat previous runs... at least thats the theory I guess.
Old 02-24-2021, 08:50 PM   #4
SSDiv6
NOPE!
I do not condone or support the use of devices to deceive or cheat. However, when I managed the Trophy Truck engine shop, my tuner had a background with import car drag racing and he had developed lots of programs to control high horsepower import cars so they could hook and go straight down the track, especially FWD cars.
He used similar parameters on the Trophy Truck ECU software that helped the trucks perform better at races such as Baja. Because of the features, his preferred ECU is Motec which happens to be one of the most expensive ECU's in the market.
Old 02-24-2021, 09:17 PM   #5
gmeyer
Liked 35 Times in 16 Posts
Lets say all these things are true Does NHRA have the means to police it and or stop it i don't think so
gmeyer is offline   Reply With Quote
Old 02-24-2021, 09:44 PM   #6
SSDiv6
I put tuners at the same level as hackers...
OEM's have even tried too many times to prevent the aftermarket to access their ECU's...still, there are many that find the way around.
