Old 02-04-2021, 07:42 AM   #2
Painter
Liked 162 Times in 45 Posts
Default Re: Towing w/ a gas/electric cart
Electric carts have instant torque when you take off. And there are aftermarket controllers that make even more power. Simply upgrading the battery cable size helps.
BUT, all the disadvantages are amplified when you tow with one. The batteries run down quicker and don’t last as long. Make certain you price a set of batteries to fit the cart you are looking at before you buy. They are not all the same. Buying gas every week is a lot easier than $8-9 hundred dollars all at once. When one battery goes bad you better put in a set.
Painter is offline   Reply With Quote
