Old 01-25-2021, 07:54 AM   #1
james schaechter
Default Re: 360 hp 350 SBC added to 1970 Nova
I think the longer wheelbase puts them in a different review category. I think it is great they added it. I will say, to be honest about it, this is a super good combo in a Camaro. NHRA gifted it and it has been fairly well protected so I could see why they carried it over to the Nova.
The h.p. factor for that engine comes from many years of it being run in the '70 1/2 Camaro.
I for one have discussed multiple times at length via email and written correspondence with NHRA that the early Camaro and '68-72 Nova (actually they are Chevy II's in '68 and Novas from '69 on) should not be considered as the same platform. They share a front sub frame and rear axle housing and that's about it....and even the rear housings have different spring perches as the springs are splayed differently front to rear. GM actually classifies them as different platforms...'F' for the Camaro and 'X' for the Nova.
But the fact is, these cars were built and should have been in the Guide since 1970. The only unfortunate thing is that the weight break didn't end up in the 9.40's as some of the initial paper work on shipping weights indicated it might. -Al
James Schaechter 3163 STK
Old 01-26-2021, 11:47 AM   #2
Jim Cimarolli
Liked 166 Times in 46 Posts
Smile Re: 360 hp 350 SBC added to 1970 Nova
There was an original unrestored 70 LT1 Nova on Ebay last night that sold for over $142,000.
Jim Cimarolli is offline   Reply With Quote
Old 01-26-2021, 01:45 PM   #3
Greg Hill
Liked 279 Times in 68 Posts
As some of you know I’ve run these motors for years. Both the 70 LT1 and the 71. The only difference is the compression with the 70 being a point or a little more higher. Andrew’s car runs pretty good, but it wasn’t cheap to get it there . Lots of cams, converters, carbs, headers,ring packages, etc. it’s fairly easy to get to 7 or 8 tenths under, but the last 4 or 5 tenths are expensive.
Greg Hill 4171 STK
Old 01-26-2021, 03:57 PM   #4
ron mattson
Liked 69 Times in 32 Posts
What Greg said!!!^^^^^^^^^^^^
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
