Old 01-12-2021, 07:18 AM   #1
SSGN
SSGN's Avatar
Liked 140 Times in 51 Posts
Thumbs up Re: Gen 6 BBC Oil pan??
Originally Posted by Barry Polley View Post
These are an amazing pan but the only stock appearing is the CP207 and its only for the Gen 4 (IV). Cant seem to find this configuration/mods for a Gen 5 or 6.
Thanks
The more people I meet the more I like my dog
Kevin
Old 01-12-2021, 10:52 AM   #2
Barry Polley
Guest
Posts: n/a
Default Re: Gen 6 BBC Oil pan??
Thanks
Did you speak with Jake? He might be able to help you. You could purchase an inexpensive 5-6 quart and have him do it up.?
Might add, be careful going with a truck pan (extended sump) it runs into the steering link. That takes longer idler and pitman arms 5.90”. Rare Parts inc.
Old 01-14-2021, 07:34 AM   #3
SSGN
SSGN's Avatar
Barry
I have looked and no cheap or stock pans for the Gen 5/6 that will fit in the Chevelle chassis. I am thinking of taking the truck pan and modifying to fit and put my own recipe in the pan at that time. This is for my Dads car and it will never be raced.
Kevin
Old 01-14-2021, 06:50 PM   #4
Terry Cain
Terry Cain's Avatar
Liked 230 Times in 106 Posts
Is there an approved Gen 6 pan?
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 01-31-2021, 09:36 PM   #5
SSGN
SSGN's Avatar
I got tired of the Gen 6 pan options and decided to go with a pan with some nice features for the $$ and made in USA. No pans available for the Gen 6. This is not a stocker however i really wanted a stock looking pan but nothing out there so decided on this pan. Thanks to my classracer friends for the input.
https://www.jegs.com/i/JEGS/555/50232/10002/-1
Kevin
Old 02-15-2021, 09:45 AM   #6
SSGN
SSGN's Avatar
Lightbulb Re: Gen 6 BBC Oil pan?? UPDATE
I purchased the Jegs pan and it is very nice for the $$$. Not stock appearing but full of great features. I left the mounts off and engine went straight back and down, Frame clearance is ok however the steering linkgage touched so I clocked the idler arm and that fixed that. The steering will just touch on full turn lock. Hope this helps other down the road.
Kevin
Old 10-18-2021, 05:46 AM   #7
SSGN
SSGN's Avatar
Just an update. The jegs race type pan is not the best for this application. I have tried eurothane mounts,shimming the mounts and loosening steering(idler arm) and moving it slightly. The steering (inner tie rod) hits the pan on tight maneuvers. This is not a race car and Dad is not a fan. Some have said use solid mounts and shim them.Dad says he doesn't want it to shake like an old wagon. So back to searching for GM oil pan # 12495360. This is the only stock pan i can find for this application. Thanks to everyone for the input.
Kevin
