Old 01-10-2021, 10:40 PM   #1
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: Front coil springs
Talk to Marty at Rineharts and he will sell you the right spring, with the right spring rate and length. Cutting the springs affect the spring rate making then stiffer.
Old 01-11-2021, 10:22 AM   #2
Run to Rund
Liked 54 Times in 27 Posts
If the Camaro is like the A-body spring seats, both upper (in the frame) and lower (the A arm) are formed and the end of the spring should seat near the end of the formed cup, with sight holes to help. I have a BB Olds F85 and run Moog/McQuay etc. 5230 with 3/8 coil cut from each end. That gives the correct wire end relations and avoids getting into the part of the spring where the coils start getting far apart, which keeps it from seating level.
Old 01-12-2021, 08:46 PM   #3
Matt S
Liked 20 Times in 12 Posts
As others have said, call Marty Rinehart. He got me the correct Santhuff/Landrum springs the first time, no trimming required, exact stance I was after.
Matt S is offline   Reply With Quote
Old 01-13-2021, 11:09 AM   #4
nhramnl
Liked 358 Times in 83 Posts
Guys who know what they're doing (like Marty Rinehart and many good chassis builders) will tell you that there shouldn't be much guessing (where you install and check, cut and re-install, etc.). If the weights are known, there will always be a range of spring rates around that weight. You pick something that is likely to put you low, medium or high and you'll be very close. If you find you're not exactly where you want to be, just change to the next stiffest (or softest) spring.
Old 01-15-2021, 03:00 PM   #5
NHRA1926
NHRA1926's Avatar
Liked 230 Times in 68 Posts
Thanks every one. Called and talked to Marty Rinehart. Ordered a set of Landrum springs and Santhuff shocks. Great guy to deal with. He suggested which spring to install. Just received them today, and going to install them this evening. The shocks were going to take 4-5 weeks to build. He offered to remove the ones from his own car, (which only had 5 runs on them) and send them to me so I could get it back together so we could have it ready for the baby gators. What a great guy to deal with. You don't see that kind of customer service hardly anywhere now days.
NHRA1926 is offline   Reply With Quote
Old 01-15-2021, 03:24 PM   #6
Joe Martens
Joe Martens's Avatar
Liked 196 Times in 69 Posts
Great people to deal with!
Joe Martens AA/Stock 3969
Joe Martens is offline   Reply With Quote
Old 01-15-2021, 10:54 PM   #7
Wayne Scraba
Liked 186 Times in 48 Posts
Marty helped me out with springs for my Nova. I have nothing but good things to say. Great tech. Great product. Great service.
Wayne
Wayne Scraba is offline   Reply With Quote
