Old 12-15-2020, 05:27 PM   #11
Default Re: Rear end Gear lube
Laugh if you want to but I've used Dexron for years.
My experience is to break the gears in with conventional stuff first.
I used Dexron in Doug Nash 4+ 1's for years.
Old 12-15-2020, 05:53 PM   #12
SSDiv6
Many of the newer OEM stick shift transmissions require ATF. Seen too many people go to a quick lube type of shop and have the ATF replaced with gear lube and then have problems shifting.
Had a neighbor complain at one time that he had the lube on his stick shift car changed and they had damaged his transmission because it was difficult to shift. Had him show me the invoice and they had put 90W140 gear lube. Asked him for his owner's manual and it showed it required ATF. Told him to go back to the shop and have them replace the oil with ATF. He came back and said the problem was gone. Told him he and the shop were Morons; him for not looking at the manual and the shop for not knowing what they were doing, especially with a kid working at minimum wage.
Old 12-15-2020, 06:37 PM   #13
Jim Caughlin
Liked 805 Times in 245 Posts
Gibbs Qualifier oil, drag race applications never get gear lube up to operating temps unless you use a heater so the qualifier oil is the best compromise.
Jim Caughlin is offline   Reply With Quote
Old 12-15-2020, 07:24 PM   #14
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
There is a straight 50w gear lube available for HD Truck transmissions like Eaton-Fuller, we used it religiously up north in the oilfields, I've often though it would be a good balance between normal 'thick' gear oil and dexron or engine oil, as I've known a few guys that ran 5w20
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 12-15-2020, 08:13 PM   #15
SSDiv6
Talking Re: Rear end Gear lube
With you guys up North, even airliners have to use a different fuel and turbine engine oil! Many vehicles require even a different type of power steering fluid to operate in cold weather.
Old 12-16-2020, 06:44 AM   #16
GTOMayhem
Liked 22 Times in 14 Posts
ATF or Gear Lube?
Rick Thomason
GTOMayhem
GTOMayhem is offline   Reply With Quote
Old 12-16-2020, 08:24 AM   #17
Billy Nees
Liked 7,864 Times in 1,750 Posts
ATF
Billy Nees 1188 STK, SS
Old 12-16-2020, 08:28 PM   #18
Dave Gantz
Liked 251 Times in 125 Posts
Originally Posted by GTOMayhem View Post
ATF or Gear Lube?
Rick Thomason
GTOMayhem
I'm thinking all Dexron is ATF?
Old 12-18-2020, 06:19 AM   #19
GTOMayhem
https://sdparts.com/i-24092698-acdel...caAm2YEALw_wcB
Rick Thomason
GTOMayhem
Old 12-22-2020, 02:52 PM   #20
Chuck Gallagher
Liked 134 Times in 28 Posts
I have never found any rear end gear lube that performed "better" when doing the late race hot laps and for wear protection then Mobil1, 75W90 full synthetic.
I use the same in my RWD vehicles.
I used to go through at least one gear set every season; now I still run the same 9" ford Pro Gears that I ran 20 years ago.
Ask the rear end set up guys in NASCAR.
Chuck Gallagher is offline   Reply With Quote
