Old 12-06-2020, 12:53 AM   #41
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Super Stock GT... new rules
I see they kept the cage requirements down to GT/GA even after they changed the weight breaks but state that if you run 9.99 or under a cage must be installed. I figured they had moved it down to GT/KA and never bothered checking.
Old 12-08-2020, 12:13 PM   #42
Henrys Toy
Liked 520 Times in 176 Posts
There was only one class at first, I believe.
If my memory serves me correctly ( it usually doesn't ) there were three class's in Super Modified. A was for big blocks with an 850 carb and B & C were small block cars with a 750 carb. I don't remember the weight breaks anymore, but IHRA ran that as a eliminator. I also think you had to use Factory heads and were only allowed porting 1" in on the intake surface an 1" in from the bowl side. For those of you that were involved in Super Modifieds at the time, please refresh my memory.
Henrys Toy is offline   Reply With Quote
Old 12-08-2020, 12:31 PM   #43
blkjack
blkjack's Avatar
Liked 55 Times in 19 Posts
75' First year on one A/SM . 10.5 lbs/ci
76' A,B,C. A became C at 10.5, B was 9.5 and A was 8.5.lb/ci
Changed again when modified eliminator was shut down in 1981
Today, there is A thru I/SM in Comp and is entirely different.
However, modified stock is similar to the old SM rules ex.SS/AS is 8.5 with 1 carb.
blkjack is offline   Reply With Quote
Old 12-10-2020, 12:44 PM   #44
bykr
Liked 167 Times in 81 Posts
And C was inline head only, basically a class for Chevy's.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 12-10-2020, 02:00 PM   #45
Glenn Briglio
Glenn Briglio's Avatar
Liked 974 Times in 310 Posts
Not just for Chevies anymore
Glenn Briglio is online now   Reply With Quote
Old 12-10-2020, 02:48 PM   #46
Jim Caughlin
Liked 805 Times in 245 Posts
If you go back to the very beginning, Rick Voegelin from Car Craft made the original proposal. It was just the one class (for iron wedge heads, 750 carb, 10.5 tire) and was intended to be a stand alone heads up Jr Pro Stock sort of deal. When it actually got accepted by NHRA, it was just a class added to Modified Elim (not a separate eliminator). Fairly quickly after that, it expanded into 3 classes.
Jim Caughlin is offline   Reply With Quote
Old 12-10-2020, 02:54 PM   #47
SSDiv6
Due to the dominance of the Ford Cleveland engine powered cars, they had to revamp the class.
The old class resembles more the current SS/Modified Stock classes than Comp Eliminator Super Modified.
Old 12-10-2020, 03:42 PM   #48
Mike Jones
Liked 684 Times in 289 Posts
Click the link in post #24
Old 12-15-2020, 10:50 PM   #49
Adger Smith
Liked 880 Times in 311 Posts
Originally Posted by Hacksaw View Post
It has never been legal to replace the steering box with a rack in SS/GT cars or change to tubular a-arms.
Yes, I know, but there are cars out there that have them.
That was my gripe with some rules and builds that have been showing up that skirt the rules.
If they weren't out there why the need to be rewriting (change the language) of the rules?.
Adger Smith (Former SS)
