#1 | |
Liked 302 Times in 73 Posts
[QUOTE=Stephen & Horace Johnson;628251]
Additional info; were making 300-350 HP tops... not a speed demon by any means haha Brad Last edited by HawkBrosMav; 11-18-2020 at 02:41 PM. |
Liked 36 Times in 26 Posts
I had a few Boss 302 cranks I ran for years, and then I broke a crank, caught it in time. But the metallurgy has changed, So I ran this Boss 302 crank for a long time came to rebuild with rods and pistons, and I opted for a new crank. The cranks wear out. I felt better with a new crank that was made for neutral balance, that one that had seen service since it was made
Liked 1,583 Times in 582 Posts
Go neutral balance and get the crankshaft from Molnar Technologies. Every time I use Eagle or Scat, it requires work to correct issues.
Liked 240 Times in 112 Posts
I've got a 28oz cast crank 351c that goes to 7300. It's been together 7 years and didn't get twisted that high till I figured some things out. I had a local machine shop balance it and it feels smooth @ rpm. The external balance gives a tiche less iron flying around Inside the crankcase.
I've also got a recently acquired Molnar massaged crank for my good engine. That's going to be a while though, too many projects.
Dave Noll, EF/S ,?/SA 6526 |
Liked 132 Times in 30 Posts
Bret Velde could probably shed some light on the subject I believe he played with external balanced SBF a long time ago.
Gary Smith "another broke racer spectating" |
Liked 776 Times in 199 Posts
Brad, we did pick quite a bit going from 50oz to 28oz, but we also changed some other things to, so not sure how much was just the change in the weight.
Bret Velde 2003 ??/SA |
#7 | |
Liked 161 Times in 52 Posts
[QUOTE=HawkBrosMav;628254]
also makes a difference if its stick or auto.I was turning my sbf 68-7.... I'd rather be safe then sorry I have not had any issues with scat or eagle in my engines or the ones I have built for others ... maybe I was just lucky .....good luck
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#8 | |
It is touch and go with Eagle and Scat. I have heard that Eagle improved their machining, but some issues still linger. The last two Scat crankshafts I used, required rework. Still, if a replacement crank is available from Molnar or Callies, that is the way I prefer to go. Everything I get from Tom Molnar is right on the money. Tom was the guy at Oliver Rods for many years and the quality of his products is outstanding and he stays behind his products. |
#9 | |
thanks for the input all |
Liked 288 Times in 90 Posts
Brad
In your Combo a nice well prepped OEM crank will work great at 6500 rpms. Cryogenic treatment helps but it’s not a must. Eagle steel crank 3.00 stroke neutral balanced turning 8800 for 2 years now with no issues. Good luck.’ RJ |
