Old 11-16-2020, 08:54 PM   #1
Randy Wells
Liked 1,144 Times in 354 Posts
Default Re: Lug Nuts
Originally Posted by Jack Zimmerman View Post
Something that hardly ever seems to get mentioned about the typical 5/8" wheel drive studs that a lot of us use is that the shoulder that fit's into and locates the wheel is actually 11/16" in diameter. This is the same diameter as the shank on a standard 7/16" or 1/2" threaded straight shank lug nut made for racing wheels. The 5/8" part of the stud is just the thread size. So if you want to use 5/8" drive studs, the holes in the wheels need to be 11/16" diameter. If the wheel is made for use with conical lug nuts it may not work with the 5/8" studs unless it's drilled out and has enough material left to bear on the stud without deforming under hard acceleration.
That is why I am going to go with 1/2" studs, don't want to drill the wheels. Thanks Jack
Randy Wells
I/S 5628
Randy Wells is offline   Reply With Quote
Old 11-17-2020, 08:51 AM   #2
Liked 10,746 Times in 2,235 Posts
Something to think about, cost of 5/8 studs vs repair cost and body work.
When I broke my 1/2 studs it ruined a 71 Cuda bumper, painted Grill, and a gilled fender. The grill was just north of two grand.
Old 11-17-2020, 10:04 AM   #3
rod butcher
Liked 132 Times in 27 Posts
We sheared a wheel with 1/2" studs like Larry did but were lucky and no damage to the body. I would drill wheels and put 5/8" studs if I were you.
rod butcher is offline   Reply With Quote
Old 11-17-2020, 10:10 AM   #4
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
If you run the 1/2 inch please note that you’ll need to bring extra studs (or be fortunate enough to be racing with Mike McMahon since he’s carrying extras even though he doesn’t use them anymore, ask me how I know). Matt Rover spotted my broken studs and that’s on a SS/MA car, turns out I was about to make a run with two broken studs, which of course would have been a very costly mistake.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 11-17-2020, 02:30 PM   #5
CMcAllister
Liked 920 Times in 259 Posts
I always insist on 5/8" stuff for anything more exotic than an 11 second street car.
Radial tires, manual transmissions, better track prep...
It's a one time expense that's not a large $$ figure vs. what happens when you shear the small studs.
Old 11-17-2020, 02:37 PM   #6
Jeff Stout
Liked 704 Times in 281 Posts
You guys are making me nervous. 10.0 car with trans brake and 1/2 studs for 8 years
Old 11-17-2020, 06:25 PM   #7
bykr
Liked 167 Times in 81 Posts
I think most stud breakage is due to inadequate clamping force .ie lug torque.. Plenty of fast cars on 1/2" studs for years.
Tim Schmackpfeffer 762 SS
bykr is offline   Reply With Quote
Old 11-17-2020, 06:36 PM   #8
Randy Wells
Well between Larry and my Brother Bob and the stories, looks like I will go with 5/8". Looks like plenty of meat on the wheel to drill out for Lug Nuts.,
Old 11-22-2020, 01:36 PM   #9
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Lug Nuts
I know how you know. Jim
