Liked 189 Times in 48 Posts
Do you have access to scales?
My first GT car was a Quay car. I was able to correct that tendency w/o a anti-roll system with more preload in the right top bar and a little extra height (3/4") on the driver side front spring. That being said - there's nothing wrong with an anti-roll system. Also - downward (nose down) rake on both bars (top and bottom) helps to limit the amount of roll.
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA Last edited by Angelo DiTocco; 11-09-2020 at 03:10 PM. |
#2 | |
Liked 704 Times in 281 Posts
Liked 125 Times in 59 Posts
Larry this may seem crazy to you but it really helped mine. Once I got to 5.60s it was a hand full. Just an option to keep in mind.
Liked 99 Times in 60 Posts
Curtis, I like that, a good idea and easily done. Do you also employ an anti-roll bar?
Larry Woodfin 471W |
Liked 34 Times in 12 Posts
I have built two of these cars and have not had problems with body roll, not sure if it is how they were setup or lack of power, lol.
I worked with Ed 20 years ago and he provided details on the setup that are still in my car today. My car is setup neutral- no squat and no separation. I have some preload in top passenger bar but minimal. Bottom bar is 2 degrees down, cannot remember top bar location. I scale car with 40# more on driver rear than passenger rear. Front is same side to side. I did have driver front springs 1/2 coil higher initially but went to Santuff springs which are equal. Never saw a difference in roll. In my humble opinion- if the shocks are set soft, rear springs are soft or 4 link is set for excessive squat- you could have the body roll. It appears some cars require anti roll bar and some do not, everybody has a different recipe. |
Bert, Thanks, I appreciate the note.
Larry, occasionally and I never knew when this would happen before I added the swing arm. I had made 3 passes before this straight as a string.
I haven't got to leave off the brake with it yet but here it is off the foot with the swing arm. May not be apples to apples with a door car but I just wanted to show you what I did and why I did it. |
Liked 880 Times in 311 Posts
Larry,
Put one on the car. You can always disconnect the links if you don't need it. My V-6 car has one and my new Quay car has one. Better to build it in the first time, even if you don't use it was my thought.
Adger Smith (Former SS) |
