Old 10-31-2020, 11:23 AM   #1
Bunkster
Liked 43 Times in 10 Posts
Default Re: "Old School" Stocker Cams
Ford 292 lifter:
Bunkster is offline   Reply With Quote
Old 10-31-2020, 02:41 PM   #2
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: "Old School" Stocker Cams
Seems that many an engine assembler putting together a 292 or a 312 would get his bare block on the stand, stick in the cam, the crank, the front cover and balancer, then put in the pistons and the rods, button things up, install the pan, pickup and the pump, then turn the engine over and start to install the lifters and then discover one of Ford's better ideas. It was the FE engine that went with a conventional lifter which Ford stayed with ever since. The lifters went into the block on the Y block first, then the cam slid in, then the rest of the bottom half went together. Lots of Ford line mechanics had a set of spring clothespins in their toolbox to hold those lifters up so they could replace a camshaft in the car if need be.
Old 11-01-2020, 11:03 AM   #3
SSDiv6
Originally Posted by Bunkster View Post
Ford 292 lifter:
Mushroom lifters were used in the early days of NASCAR, allowing camshaft profiles with more aggressive lobes. Direct Connection used to sell mushroom lifters for Mopar applications and also the required tool to modify the block.
Many years ago I heard the story of a racer that was running mushroom lifters in 15 lifter bores and left one bore with a normal size lifter in the event he was asked to pull a lifter to show tech.
Old 11-01-2020, 11:42 AM   #4
Greg Reimer 7376
Seemed to me that an old GM Performance Parts catalog used to show a mushroom cam and lifter for a small block. Also, doesn't the tech guy sometimes tell you which lifter to pull at random?
Old 11-01-2020, 01:49 PM   #5
SSDiv6
Probably expected the Tech Inspector to say, "Just pull or hand me any lifter"
