Liked 2,483 Times in 697 Posts
You can buy a piston from any manufacture = Tell them it is for superstock or a bracket car maybe some other non stock eliminator use. Then lazer cut the NHRA approval on it yourself - Is that your violation and did you not mislead the manufacturer of your purpose?
#2 | |
Liked 1,582 Times in 582 Posts
I believe that could be the scenario. However, the question is if they would admit they did it or blame the piston manufacturer and give them a black eye? It is a can of worms! If it keeps happening, I can see NHRA allowing any ring package and doing away with something else to inspect. |
#3 | |
Liked 167 Times in 81 Posts
Tim Schmackpfeffer 762 SS |
Tim,
Thin piston rings with spacers have been allowed for a long time. There are lots of piston ring designs that can achieve the same as the gas ported rings. At the end of the day, it is having the ring hone finish, a round bore and compatible rings that make the power. |
#5 | |
Liked 5,121 Times in 1,952 Posts
If they go that route, then REAL replacement Stock pistons are at even more of a disadvantage. Another shot at the budget racer, and another rule revision rammed through by the cheaters. So then what happens? Under weight pistons and rods? Knife edged cranks? Where does it end?
#6 | |
I just pointed to a plausible aftermath with everything that has taken place in the past. |
