Old 10-11-2020, 10:10 PM   #1
1347
1347's Avatar
Liked 1,001 Times in 276 Posts
Default Re: stockers
Originally Posted by L.Fite View Post
So... while we are talking legal/illegal...
How is a head with 118cc combustion chamber a replacement for a combo with 103cc chamber?...
Oh and bigger intake valves too...
Wanting to build a motor but, very confused as to how all this works...
Would build an iron head but castings cost as much as aftermarket aluminum...
So not seeing a lot of advantage other than moving weight...
Maybe should be in tech, but seemed to fit the thread.
Seems to be a lot of gray... or maybe I'm just not too smart...
You are speaking in code. You should probably put this post in the tech forum, tell us what combo you are contemplating building, and ask these questions.
It really doesn't fit the thread, the topic is about people claiming the class is filled with cheaters. Which I don't agree with. An approved head by NHRA is not what this topic is about. Does your combo which allows an aluminum head carry more hp?
Again, move this post to the tech forum and you will probably get answers.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 10-12-2020, 04:59 PM   #2
L.Fite
Liked 497 Times in 243 Posts
No code... just a general question...
It does fit as an example of the grayness I see in the rules...
Sometimes it is so confusing especially with the approved replacement stuff.
I'll go sit in the truck... can I change the station on the radio?
L.Fite is offline   Reply With Quote
Old 10-12-2020, 09:35 PM   #3
1347
1347's Avatar
What is the combo you are questioning? And what is the replacement head that you are allowed to run? The "code" part is that you are vaguely asking about an approved replacement head without even talking the specifics.
Duane Hoven
1342 SS/GT
Old 10-13-2020, 08:48 AM   #4
Liked 10,745 Times in 2,235 Posts
I think all aluminum replacement heads for the OEM heads carried a 5 Hp. penalty to start with.
Old 10-13-2020, 11:22 AM   #5
Capri
Liked 27 Times in 14 Posts
I have had the only car with my combination since 1996 that has stayed in current competition. There was at least one other that was built and raced. Said racer was told not to accept our help cause we were cheating and would not give them good information. Said racer also sold car after not being able to get the car to go any faster and moved on.
In the last few years, another racer is running a similar combination to mine, but it has a different HP rating. YET every single aspect of the parts in numerics are the same. From head casting, to throttle body, to piston size. HP rating difference from one car to the other is 50 factory HP!!!!!!!! No clue what their car weighs compared to mine, and really doesnt matter. We both are doing our own thing. Ironically, we run about the same. A pair of one off combinations, even though every aspect of the motors are identical. If one of us had something funny going on, Im sure the barn would tell the tale very quickly. Many years ago, my stuff was used for measurements cause I was the only game around.
You take a 305 chebbie, where everyone has on in Stock eliminator............ and it fits how many different cars with how many different castings to mix and match............Id say its a whole lot less easy to find someone who is doing something completely out of whack.
Or like earlier said Duster who has been MIA now. Class racing with a big inch bracket motor and getting whacked............. Yeah, we dont like that. Mistakes are one thing........ Like a well known Hemi racer installing the wrong motor for Indy and wondering why he was slower than the other AA cars at the time........... blew it up and found out what motor was in the car............ Didnt like 0wt oil....... OOPS. He laughed and left the track with a short suspension from what I recall....
But then again, a 9" radial is still not legal, right?
Capri is offline   Reply With Quote
Old 10-13-2020, 11:28 AM   #6
doglover44
doglover44's Avatar
Liked 489 Times in 227 Posts
When did that all happen ?
Jake Biermann
Old 10-13-2020, 12:09 PM   #7
GTX JOHN
Liked 2,486 Times in 697 Posts
You can buy a piston from any manufacture = Tell them it is for superstock or a bracket car maybe some other non stock eliminator use. Then lazer cut the NHRA approval on it yourself - Is that your violation and did you not mislead the manufacturer of your purpose?
John Irving
741 Stock
741 Super Stock
Old 10-13-2020, 01:49 PM   #8
Jon Sarrett
Jon Sarrett's Avatar
Liked 140 Times in 46 Posts
The Duster incident happened last year at the Joilet points meet. He was the D3 rep in stock and could hardly run the index (post teardown) after going consistently .80-.90 under for years. I've been through many teardowns and NEVER lost 8 tenths or more.
Jon Sarrett
Stock 3779
Jon Sarrett is offline   Reply With Quote
