Old 10-09-2020, 06:33 PM   #1
Dissident
Liked 73 Times in 36 Posts
Default Re: Front tire pressure/Reaction time
Staggering the wheelbase left to right is an easy way. So is choosing larger diameter front wheel/tire combinations. Some cars can also be creatively manipulated with the front suspension (extension) on launch.
When you tech in, if wheelbase left to right is measured, it is with the vehicle in a static condition. Of course check the rulebook to see the allowable tolerance on the wheelbase one side vs the other.
Regards to All that like this kind of stuff,
HB2
Dissident
Dissident is offline   Reply With Quote
Old 10-09-2020, 06:56 PM   #2
Hacksaw
Liked 310 Times in 174 Posts
The wheelbase can be + or - 1" of the factory spec. The max. diff in stagger is 3/4".
Old 10-09-2020, 09:03 PM   #3
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
here is an example : my lights where terrible in the first part of the double header @ epping divisional and went out first round because of it ,, made a whole sale change with tire pressure fronts and back (up the pressure) i had some very consistent light's from time trials to when i went in third round in the sports nationals .035-.019 ,, the .019 was against buba linke and resulted in a double breakout .002 mov for buba
just my 2 cents
Old 10-09-2020, 10:26 PM   #4
e vassar
Liked 271 Times in 107 Posts
I see a lot of racers checking and maybe adjusting front tire pressure in the staging lanes.
I wished I was consistent enough on the bottom bulb to adjust my RT,s with 4-5 lbs of front tire pressure. I set mine to about 38lbs at the beginning of the day and forget about it
Old 10-09-2020, 11:07 PM   #5
Stewart Way
Liked 70 Times in 22 Posts
Hacksaw. Think the rule is the opposite. +-3/4 with max variation 1" side to side.
Stewart Way 2424 SS
Old 10-13-2020, 04:50 PM   #6
Hacksaw
You Sir, are 100% correct.
Old 10-13-2020, 05:04 PM   #7
Ed Wright
Ed Wright's Avatar
Tech guy told me one inch side-to-side. I use 3/4 inch. Been checked a couple of times.
And pressure effected my foot brake cars more than the trans brake car. Testing would be required to determine how much, IMHO.
Ed Wright 4156 SS/JA
