#1 | |
Liked 880 Times in 311 Posts
Back in the IHRA days I had a customer that ran a Crate 385 in a Malibu wagon. The 7.5 would last about 50-70 runs and spit out the pinion or take teeth off the ring gear. That was with a good spool, caps and axels. Went to the 8.5 and the ring and pinion problems stopped. As a by product he was able to get better brakes on it, too.
Adger Smith (Former SS) |
https://gbodyforum.com/threads/86-44...ear-end.79216/
This is not my diff. I have had good luck sourcing parts from car specific forums. 1500 US seems high but that may be the current rate. |
Liked 985 Times in 198 Posts
Isn't a 7.5 rear end the same rear end they put in Vegas in the 70s?
Liked 71 Times in 23 Posts
Friend of mine has a 87 Grand National rear end for sale, 3.90 gear TA Cover, stock axles, good drum brakes. He is In Illinois, but will be going to SGMP in a couple weeks for ducks race. He can deliver between Illinois and SGMP $1,600 obo
Monte Howard 3209 STK, 3208 SS |
Liked 705 Times in 219 Posts
Man,I hope not! In the 70's when I worked on the line at the Chevy dealer, the Vega had a ring and pinion pitch noise(howl) at about 30-35 MPH. You could adjust pinion depth, experiment with back lash, do whatever you want, but that rear end was going to howl. We were so glad as more and more Vegas went beyond warranty because we knew people weren't going to spend money on a Vega to fix it. We never really came up with a real fix for that unit, it just seemed to be a real poorly machined piece. Quality control was nonexistent anyway on those cars. Also, when the Chevette came out in 1976, every last one you would ever drive had a pitch noise that would come in at 40 MPH. You didn't need the speedometer to tell when you hit 40, the rear axle assembly would tell you. Also, full sized vans did that, too, although trucks wouldn't even though they had the same rear end assembly. Later on, it dawned on some of us that the Vega, the vans and the Chevette all were unit body with the rear end bolted to a unit body. It was possible that setup transmitted a normal noise to the passenger compartment that the separate frame and body with mounting bushings somehow isolated it. I was nervous about smaller rear ends not only from the strength standpoint, but wondered if the noise came from poorly machined or mismatched parts somehow.
Liked 450 Times in 133 Posts
You are right Greg the G Vans were horrible with rear end howling new or used years ago ive had race car rear ends that didnt howl as bad as them. going back to the original question go ahead and buy the good stuff now for a 12 bolt and then no worries.
Jerry Retired 3490 3492 STK SS SST Last edited by Jerry Terry; 10-05-2020 at 03:29 PM. Reason: add |
Liked 17 Times in 3 Posts
Where or Who do you guys recommend for a 12 bolt replacement? Moser/Strange? Thinking of ordering a bolt in 12 bolt for a 4th Gen Camaro... I'm thinking it would be best to just order the whole ball of wax at one time..
Liked 358 Times in 83 Posts
[QUOTE=Jerry Terry;625161]You are right Greg the G Vans were horrible with rear end howling new or used years ago ive had race car rear ends that didnt howl as bad as them. going back to the original question go ahead and buy the good stuff now for a 12 bolt and then no worries.
The G-van rear axle howl was always kinda figured to be attributable to the fact that the operator was driving a huge "speaker" down the road. Or maybe better referred-to as a megaphone. Pickups probably had noise too, but you just couldn't hear it in the cab. |
