Old 08-15-2020, 12:03 AM   #5
CMcAllister
Liked 920 Times in 259 Posts
Default Re: Wire Shielding EMI or RF Noise?
I keep ignition wiring and "dirty" lines (alternator, fans & motors) separated as far apart as possible. And twist or braid the ignition trigger wires.
All grounds are connected to the ground post of the battery with copper - wires, cables. Don't rely on sheet metal.
Would be interesting to see what happens if the alternator is not functioning on a pass.
