The above, and the smaller diameter of a dampener, versus a flywheel, the effect on inertia won’t be big.
Ed Wright 4156 SS/JA |
Liked 734 Times in 385 Posts
Exactly. Plus it also depended on how fast the rate of acceleration of the engine is. A 1 lb weight on the outside of a 6" diameter accelerating at 2000 RPM per second at 7000 RPM is taking less than 0.54 HP. Where as that 1 lb on the outside of a 12" diameter accelerating at 2000 RPM per second at 7000 RPM is taking 2.17 HP.
Stan |
Liked 565 Times in 70 Posts
I put it in the category of things that dont show a measurable increase but when added to 50 other things like that, all of a sudden your a little faster. Lol
Thanks you for your insightful replies to my question.
Bernhard |
Liked 6 Times in 2 Posts
I'll add a couple things with no verifiable info to suggest I'm correct however.. Almost all balancers are neutral or zero balanced so a change won't affect anything internal. Smaller/lighter should spin up faster but as mentioned, you'll never notice it. What is important is the name "Harmonic". A small lightweight balancer can't control internal harmonics like a heavy "factory" one does. Bearing or crank failure can be the result. Some engines and balancer brands are notorious for this.
Hopefully, a real expert chimes in here but i can guarantee you'll se nothing performance wise. Kinda similar to Roller Rockers that are magically going to add HP> JMO
Dale Posnick |
#6 | |
Liked 2,486 Times in 697 Posts
added to 50 other things like that, all of a sudden you're a whole lot poorer. Lol AND THEN = Your crank is in two pieces!
John Irving 741 Stock 741 Super Stock Last edited by GTX JOHN; 08-03-2020 at 01:31 AM. |
#7 | |
Liked 497 Times in 243 Posts
Ended up with stock in Federal Mogul and had lots of two piece door stops! |
Liked 33 Times in 20 Posts
I read it again......I laughed for a minute!
It is not easy to even smile the last few months we have suffered through.
There are lots of data, including SAE Papers that show that in addition to dampening harmonics, the proper harmonic dampener will help the engine produce more horsepower.
http://www.atiracing.com/products/dampers/sae.htm http://www.atiracing.com/products/dampers/sae.htm There is a great SAE Paper regarding harmonic balancers and its effects in horsepower. https://www.sae.org/publications/tec...ontent/790763/ |
