Liked 57 Times in 24 Posts
My plots look backward compare to what everybody
Is explaining The first plot was in 3500' air and the second Was 300' air. No changes in the car at all. The graph index for A/F is 10 to 15 at the top of the graph The first plot has a 12.8 reading at top of 1-2 gear change The second plot has a reading 12.1 at 1-2 gear change Plots show lean in the worst air of the two. Am I looking at correctly. [15 lean. 10 rich]. ? This is why I am confused by readings Couldn't upload a higer resolution pictures Thanks David Last edited by Willyracer; 06-26-2020 at 10:59 PM. |
Liked 880 Times in 311 Posts
When you get tired of reading what all the experts say... Go to the track and tune your engine where it is happy.
Best ET and MPH in the conditions available. Then hook up your gauge and let it tell you what the A/F ratio is. Your dealing with arbitrary numbers and your engine combination may not be happy with them. I loved it when I was dyno testing and had customers tell me the EGT and AF had to be certain numbers to make power. Their engines usually told them something different. When making power most engines accelerate when slightly rich at peak Tq and run up toward lean at peak HP. In the car I like slightly rich at the gear change to produce Tq and pull off the gear.
Adger Smith (Former SS) Last edited by Adger Smith; 06-30-2020 at 05:35 PM. Reason: sp add |
Thanks Adger
That is the way I always tuned my bracket car for years. I never had an O2 reading to compare. Some time to Much info causes a brain overload. Lol Thanks again to everyone David |
#4 | |
Liked 704 Times in 281 Posts
#5 | |
Liked 262 Times in 74 Posts
Steve Polhill 3520 STOCK, COMP |
Liked 534 Times in 143 Posts
This is true to a point, but replacement parts don't always cost a small fortune on engines and turning them on is generally pretty easy.
Liked 1,583 Times in 582 Posts
Beer VS Tequila
If they run on beer it could be cheaper...JS
Adger Smith (Former SS) |
