Old 05-31-2020, 03:39 PM   #1
GTX JOHN
Liked 2,493 Times in 700 Posts
Default Dominator Disasters
I have 3 Dominators 2 = 9375 3 Circuits
I = Demon 3 Circuit 1050?
My Mopars a 9 Second Bracket Pigs (3200 with me)
500CI and 6500 RPM.
Jeted 84 or 85 Square no power valves
All rebuilt several times and passages checked and rechecked with everything stock and original including air bleeds.
Way Rich at top end!
Any ideas on how to modify.
I am a Stock/Superstock guy and LOST!
John Irving
741 Stock
741 Super Stock
Old 06-01-2020, 03:34 PM   #2
Hacksaw
Liked 314 Times in 177 Posts
Default Re: Dominator Disasters
Make sure you are using the metering gaskets with the question quotation mark for the 3 circuit carbs. Larger air bleeds? Starving for air in high gear?
Old 06-01-2020, 04:12 PM   #3
1700camaro
Liked 226 Times in 115 Posts
500CI and 6500 RPM.
John,
This is B King from Vegas, hope all is well with you & your family.
I hate Dominators, I can never seem to get them right. We have one on our 68 Camaro SBC. It runs pig fat in bottom to mid range, but we have made a little headway with it.
Anyway, I think part of you problem might be the 9375 model. It was designed for a 2x4 application not a 1x4 combo. Who knows maybe you are set up 2x4. I'll provide the Holley link for that carb.
https://www.holley.com/products/fuel...parts/0-9375-1
I would focus on leaning the jet or more HS air bleed. The original jetting is listed @ 86/86.
Bryan
1700camaro is online now   Reply With Quote
Old 06-01-2020, 05:39 PM   #4
Jeff Stout
Liked 706 Times in 283 Posts
http://motorsportsvillage.com/forum/...pic.php?t=3742
This page gave me the education to figure out my Dom. I never worked on 1 before past jetting and Now I tuned it pretty good. I was also to rich at idle and wide open. Changing circuitry and IAB, HSB. solved it.
Old 06-03-2020, 12:50 AM   #5
GTX JOHN
I am using correct gaskets for 3 Circuit
Did not the earlier 9375 (Not 9375-1) have only two circuits=
I was lookiing for one of those.
John Irving
741 Stock
741 Super Stock
Old 06-03-2020, 08:28 AM   #6
Jeff Stout
BLP makes 2 circuit blocks that I used to convert my 3 circuit.
Old 06-03-2020, 01:31 PM   #7
GTX JOHN
Thanks Jeff!
Do I need to make any further changes other than
the changing them for them to work?
John Irving
741 Stock
741 Super Stock
Old 06-03-2020, 09:35 PM   #8
Jeff Stout
Thanks Jeff!
No changes. Took about 4 times to get afr decent. Went through a box of brass set screws with drilling out and redrilling . It was enjoyable to work on as the changes were in a positive manner. . I think I used the blue gaskets and drilled open some of the holes in gaskets to match ports.
Old 06-03-2020, 09:40 PM   #9
Jeff Stout
Just remembered. The guide pins for block to carb body were to long. I found out as after turning on pump it poured fuel out. Filed pins alot to make shorter and not bottom out.
Old 06-04-2020, 11:05 AM   #10
340Cuda
Liked 805 Times in 341 Posts
This guy does a lot of work on Dominators and I see a lot of happy customers.
You might check with him.
https://www.facebook.com/thumpercarbs.thumper
