Old 06-03-2020, 11:40 AM   #16
Adub464Q
Adub464Q's Avatar
Liked 478 Times in 91 Posts
Default Re: Racer Self-Certification Tech Program
I know that in a future update, the online tech card program will allow you to have a profile and store your information. Therefore, the only thing that will change is the drop down menu for the event being entered.
I found the online program fairly simple, it stepped through the tech card process similar to how one would fill one out on paper.
Random thought with trying to be touchless: What about fuel check? We all touch the same cups and stand in line? Are we going to have a 6 ft spacing line? Facetious questions....
In my personal opinion, once someone completes an adequate fuel check in Qualifying, they should not be subjected to additional fuel check unless in a heads up elimination run. I think most of the time NHRA does fuel check anyway is because they need generator gas...I have been at an event with 5 qualifiers and did fuel check EVERY. SINGLE. TIME.
Austin Williams
3 SG
464Q STK SC
Adub464Q is offline   Reply With Quote
