Old 06-01-2020, 01:02 PM   #1
StompNDump
Default Re: Do these stop numbers sound right?
Its the C5 Davis
DA was 1803 Ft
StompNDump is offline   Reply With Quote
Old 06-01-2020, 01:41 PM   #2
57 Vette
57 Vette's Avatar
Liked 38 Times in 14 Posts
The C5 model Davis is a good 100 lbs lighter than the 57 model and has better aerodynamics!
57 Vette is offline   Reply With Quote
Old 06-01-2020, 02:45 PM   #3
StompNDump
It was those numbers that had me guessing. I figured a engine that size running 8.50s would have carried more in the timers or at least close to where they were set, but unfortunately that ended in a 10.56 and 10.19, So it looks like this set up may only carry a second or so on stop.
Old 06-02-2020, 08:43 AM   #4
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
If it were mine, I'd make the 'Stop On' time later and/or increase the RPM on the stop some so you can carry a little more time on the stop.
It is best if you can always be on the stop through the 60' timer so you have something that should stay constant run-to-run.
S/ST 51
S/C 53
Old 06-02-2020, 10:37 AM   #5
StompNDump
What would you recommend Lenny? Throw me some numbers and ill try them this weekend if i get to test.
Old 06-02-2020, 05:43 PM   #6
Keith 944
Keith 944's Avatar
Liked 1,877 Times in 577 Posts
just bring the rpm up somewhere around 44-4600, see where you are, then if more needed bring the first (on) time out to maybe .5-1 sec
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 06-03-2020, 08:26 AM   #7
StompNDump
Ok Ill give this a try next time out with upping the RPMs to 4400. Would 300 RPM make a big difference?
Also Ill change Timer A1- to 1.000, would this be too much ?
Old 06-02-2020, 05:40 PM   #8
Keith 944
Keith 944's Avatar
I totally agree with this
was going to mention this. i like a min of 2 sec duration on stop. ratio will be better and should be more consistent.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
