Old 05-28-2020, 10:16 PM   #3
Bradley Johnson
Bradley Johnson's Avatar
Default Re: neutral safety switch
There are a number of universal Neutral switches on the market that mount on the trans .
Glides are very easy to make your own switch for .
A split collar that fits the transmission selector shaft can be found at most good hardware stores.
By putting flat spots at the park and neutral positions on the collar ,a simple bracket can be made to mount a miniature lever style microswitch to line up with the collar.
You can find many different styles of lever microswitches on Amazon at very low prices , I'd stay with one made by Omron .
Thank you for the tip. Your way is much simpler and probably less prone to failure than what I was thinking.
Bradley Johnson
1969 Mustang Fstbk SST
Bradley Johnson is offline   Reply With Quote
