Old 05-12-2020, 10:15 AM   #1
340Cuda
Liked 801 Times in 338 Posts
Default Re: new enclosed trailer [maybe aluminum] feedback
Originally Posted by Glenn Briglio View Post
Check out Intech trailers
The nicest trailers I have seen lately.
Old 05-12-2020, 12:22 PM   #2
Glenn Briglio
Glenn Briglio's Avatar
Liked 971 Times in 308 Posts
It's not a goldrush but it doesn't have the goldrush price either.It's very nicely constructed.
Old 05-12-2020, 01:03 PM   #3
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
I would call Randy Cape at Flying A Motorsports. (800-222-4004) I drove down there (1300 mile round trip) a week ago to talk to him and see the different types of trailers they stock and what to look for in the different price ranges. He has a wealth of knowledge after designing, building and selling trailers for over 30 years. And not only that, he is a real nice guy and no high pressure to buy. Well worth the call. Dyno.
Old 05-12-2020, 01:53 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,180 Times in 972 Posts
While in the Elkhart area getting some MH warranty items taken care of I toured both the InTech and ATC facilities (tour the Newmar plant also in Nappanee if you have time). Both are top notch with completely different manufacturing approaches but I’d give the nod to InTech, their workforce is largely Amish and the craftsmanship is simply better. Beyond that I’d shop locally and support racers when possible, for instance in the west I’d call Jon Irving. In the Northeast I’d look at Chris Howe’s pick, in the Southeast I’d go elsewhere unless price is the #1 item on your list. In the Midwest, I’d second Dyno’s recommendations of talking to Randy at Flying A, they have something for every budget.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 05-12-2020, 06:53 PM   #5
Dragsinger
Liked 99 Times in 60 Posts
Thanks to all for the info. I will follow up with these listed builders.
Larry Woodfin 471W
Old 05-12-2020, 07:53 PM   #6
Ed Wright
Ed Wright's Avatar
I bought a 24’ ATC all aluminum trailer a few years ago. I would recommend ATC. I had a steel open trailer before, and the 24’ ATC is easier for my 2500 Suburban to tow. It does not feel any heavier than my old trailer, that was 2 ramps, not a steel flat bed trailer. My ATC came with electric brakes on one axle, I added brakes to the other axle. I did go to 16” wheels, with Michelin LT tires. Trailer tires, I learned, are speed rated to 55 MPH? Oklahoma Turnpikes’ speed limits are 75MPH. Trailer tires don’t like that. Don’t live well at that speed. LT tires are rated at 95 or 98?
Those 16” 6 ply LT tires (same as my ‘99 2500 Suburban uses, also are more stable. I tow the speed limits. I use 60psi in my trailer tires, same as my Suburban. Very stable.
My ATC came with nice aluminum cabinets & work bench. I would buy an ATC again.
I towed it with Jeanie’s 1500 Tahoe at first. Zero issues.
Ed Wright 4156 SS/JA
Old 05-13-2020, 01:37 PM   #7
Kenney Kelley
Liked 72 Times in 36 Posts
One thing to think about with a 1/2 Ton truck is all the weight of the truck and the tongue weight of the trailer is supported by only the size of the axle witch might be only 1" to 1 1/2" at the bearing that's a lot of stress right at that point But with a 3/4 -1 ton truck the weight is supported by the rear end housing and not the axle. Just something to think about. Plus along with the weight of the car you will probably add the weight of a generator, air compressor, tool boxes, Battery for a winch and lights, tent with chairs, fuel cans, floor jack, Golf Cart or Pit Bike, Coolers with Ice. That's just a few items you might need before heading to the track. Kenney Kelley
Kenney Kelley is offline   Reply With Quote
