04-08-2020, 10:45 PM | #1 |
Liked 238 Times in 89 Posts
Fast xfi rpm issue
Fast xfi, analog 7al2, fast dual sync dist. My autometer tach is roughly 500rpm less than what fast data shows. Fast at idle shows 1100 while tach is around 600. Is this normal or if not, what is the fix. I honestly thought I had a low reading tach before I put on efi, just now I have another reference that should be super accurate since its dual sync
04-09-2020, 08:34 AM | #3 |
Re: Fast xfi rpm issue
04-09-2020, 09:25 AM | #4 |
Liked 1,749 Times in 424 Posts
Where are you picking up the tach signal?
04-09-2020, 09:57 AM | #5 |
at the 7al2 box, tach terminal
04-09-2020, 10:34 AM | #6 |
Is there an unused tach wire on the FAST harness? If there is, it would be worth trying before changing the tachometer.
04-09-2020, 11:31 AM | #8 |
Liked 389 Times in 168 Posts
I have not had a tach in my car for a while now. I log & play back every pass. If I had a stick car, I would need one, wouldn’t I? Or a shift light. LOL
Ed Wright 4156 SS/JA |
04-09-2020, 02:57 PM | #9 |
That's what is firing the msd box. Seems the more people I talk to I am thinking it's a tach issue. Nobody seems to have this problem. And a Tach is a necessity in Stock. Foot brake, and reverse pattern ATI 350 means it's all on me lol
04-09-2020, 08:57 PM | #10 |
Liked 301 Times in 73 Posts
I have used a digital hand held tach that uses a small piece of reflective tape on the damper to verify which is correct.
Ernie Neal SS 354 |
