Old 03-10-2020, 01:54 PM   #3
Eman
Liked 133 Times in 76 Posts
Default Re: Transmission Solenoids
Originally Posted by Kenney Kelley View Post
How does one check solenoids if they don't have a factory computer? Someone told me that's how you check them. Or do you just buy new ones Thank You Kenney Kelley
You can use a wiring diagram and go to the connector at the trans or you can pull the pan to access them. Then you can use an ohm meter and or run jumpers to see if they activate, you can hear them click. Now that will check the solenoid but you won't know if there is a problem in controls or wiring.
