Old 06-02-2019, 11:31 AM   #1
Rory McNeil
Liked 1,112 Times in 304 Posts
Default MoPar stickshift parts
Quick Time scattershield for SB MoPar. SFI version with window for easy counterweight adjustment. comes with block plate. SFI sticker expired. $400.00
MoPar input shaft for G Force G101A 4 speed transmission. 1 3/16"x18 "Hemi" spline. $250.00
MoPar front bearing retainer for G101A trans. $90.00
Also have a Long shifter mounting plate only for Long Pistol Grip V Gate shifter for G101A 4 speed. standard location (20 1/2" from front of case). $30.00
Homemade shifter mounting plate for Long Pistol Grip V Gate shifter, with shifter rods. (no Heim rod ends, just the tubes). Locates shifter 26" from front of case, This bracket locates the shifter about 2 inches higher than standard position, so reverse lever on trans points up, rather than down. $60.00.
NHRA 6390 STK
M/S 85 Mustang
Old 01-15-2020, 02:32 AM   #2
68Tom440
Default Re: MoPar stickshift parts
Hello sir, is the mopar main shaft and bearing retainer still available? Thank you, have a great day.
68Tom440 is offline   Reply With Quote
Old 01-15-2020, 06:17 PM   #3
Rory McNeil
Not a main shaft, but an input shaft, and front bearing retainer. Yes, both pieces are still available.
NHRA 6390 STK
M/S 85 Mustang
Old 01-18-2020, 10:19 PM   #4
68Tom440
I apologize for that, I dont know why I said main shaft. Fantastic. I'm trying to get things situated to install a GF4A/101A behind a 440. Are you still looking to get $250 for the input and $90 for the bearing retainer? Also, if you have any advice or experience you can share on this type of trans in a mopar, that would be really awesome. Thank you, have a good day sir.
Old 03-02-2020, 03:30 PM   #5
Rod Greene
Liked 242 Times in 81 Posts
Rory you have a PM
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
Search this Thread:
Advanced Search
