Liked 10,681 Times in 2,222 Posts
After speaking with the manufacture of the ring compressor and the problem I was having. A new one of the correct size is on the way with a call tag for the smaller one. Not trying to be political, but there is something to be said of dealing with American company's.
When I first started doing this, racing stuff, who would have thought the thickness of a hair (.003") would have caused a problem unless it was a bearing clearance. |
New ring compressor arrived today just like they said it would and it was as advertised 4.125". Thanks ARP
New ring compressor worked perfect, the oil rails had the correct gap during installation.
I'm trying something different, assembling engine on the bench without using an engine stand. I'm thinking the heads are a strengthening factor to the aluminum block, that seems to move around a lot. Trying to assemble the engine without induced stress from hanging on engine stand. I'm not sure how to measure the results. Joel would ask me if I was trying pick fly stuff out of pepper. Many a truths are spoken in jest. |
Liked 799 Times in 236 Posts
Larry, the late Bob Glidden assembled his Cleveland-based Pro Stock engines on a wooden pallet on the floor for that very reason.
"That'll never work....." |
You FFFF Ford guys could have shared! LOL
#6 | |
Liked 309 Times in 173 Posts
I was wanting to try 175* oil and 100* water in the honing plates, it would be almost like a heads up run.
Had a good day today. Made an A2 steel crank key, degreed the cam in. I got my work-out in by moving the block , crank, and cam around from horizontal to vertical a couple of times. Installed all of the pistons but still have to tighten bolts to stretch. locktighted and torqued cam bolt. Its about supper time.
