Old 01-21-2020, 02:02 PM   #31
nolongerracing
Liked 72 Times in 27 Posts
Default Re: Dumbo The Flying Elephant
It changed #1 and #5 approximately .0003 smaller, the rest no change. #2, 3, and 4 are four bolt mains, 1 and 5 are two bolt mains. All mains are cross bolted. I will scotch bright back side of bearings to try to regain lost clearance. Whatever it takes, the solid feeling is worth it when torquing.
The scotch bright fixed it
Will you be using "full groove" main bearings?
nolongerracing is offline   Reply With Quote
