Liked 34 Times in 12 Posts
1982 Camaro coupe/claimed as 1986 (comes with title)
Chassis built by MPR Mike Pustelney 9" Ford with Mark Williams lightweight aluminum center section Strange axles 5.83 Pro gear ---New 15"x14" weld wheels rear---15"x3" weld wheels front Phoenix 14.5" x 32.0" bias tires rear---Goodyear tires front Lamb brakes front and rear---rears are dual calipers Koni adjustable shocks front, valved at True Choice, Koni double adjustable rear Dual Exide batterys ---New CRC combo fuel pump and filter---BG 4 port regulator---both just sent out for service MSD ignition---7AL2 box ---HVC 2 coil ACD air shifter and Hurst Quarter stick-- 2 air bottles just filled Autometer play back Monster tach New 5 gallon fuel cell Rossler lightweight Turbo 400 with brake Aluminum transmission shield ATI 8" convertor---New Dynotech aluminum drive shaft New engine fresh off dyno 1970 402/300---NHRA rated at 308h.p. GM 454 case with 8 sleeves---.060 overbore GM steel crankshaft ---reworked BME pistons Eagle H beam rods----------ARP 2000 bolts Comp cams roller cam and lifters Jesel belt drive Super Stock shoe box style oil pan with mini sump ATI balancer with aluminum hub MSD crank trigger GM 820 cyclinder head castings Manley valves Comp Cams 948 springs Jesel rocker arms Trend pushrods Dart inlet manifold 9207 Quadrajet Davis 3 step headers---just ceramic coated This car has gone 9.49 @ 139.6 mph @ 3275#s Will run GT/IA at 3250#s---GT/IA index is 10.65 Many spare parts also available. See Racing Junk Ad 183152801 Will sell complete for $38k or reasonable offer, or will sell engine only. Call Vince 586-749-0200 business hours. No texts. |
