Old 01-06-2020, 10:56 AM   #6
Lyn Smith
Liked 974 Times in 195 Posts
Default Re: SBC: 66 years and counting Quiz.
The rings did not seat so they poured Comet cleanser ( or equivalent ) down the carb while the engine was running. Trying to rough up the cylinders .
Correct. I think they called it Bon Ammi back then, and it was a mild abrasive cleaner used to clean the scum from you bath tub. LOL. They also had a problem with rocker studs pulling out at higher rpms, and since the first 265s had flat top pistons the valves dinged them pretty bad. They found out that a gauge at the head assembly wasn't adjusted right and the studs were not installed to the right spec.
