#1 | |
Liked 316 Times in 67 Posts
1956, R.P.O. 411 option.....how much?
265/225 dual WCFB's |
Liked 973 Times in 195 Posts
Randall, according to the Chevrolet book of numbers the 411( Dual 4bl carbs) option suggested list price was $225.00. With delivery and handling added $242.10 to the window sticker of your 56 chevy.The 449 option of the high lift cam was $188.30.Air conditioning was the most expensive option at $430.50.On the Corvette models the dual 4 bl stuff was only $150.65.
Corporate news release, dated 2-2-56
RPO 411 for all passenger cars dual 4's $225 list, $171 dealer cost plus 17.25 D&H (those were the days!) must specify electric wipers letter states: "we expect the demand for this option to be rather restricted" |
In 57 when the fuel injection version of the 283 was released it was said to be the first engine to make 1 H.P. per cubic inch. When some doubtful GM engineers got around to putting one on a dyno what horse power did it actually make?
Liked 481 Times in 158 Posts
What did the Bon Ami do to the engine oil/ bearings ?
Correct. I think they called it Bon Ammi back then, and it was a mild abrasive cleaner used to clean the scum from you bath tub. LOL. They also had a problem with rocker studs pulling out at higher rpms, and since the first 265s had flat top pistons the valves dinged them pretty bad. They found out that a gauge at the head assembly wasn't adjusted right and the studs were not installed to the right spec.
